| Message |
and you watch it from underneath.. if the rod always moves the same time the clutch peddle moves, then it's LIKELY an internal clutch problem.. Ball Broken, or the Clutch disk or Cover is coming apart.. Clutch has to come out to check.. If the peddle moves for a a bit, then the clutch rod starts to move, it;s an external Hyd Clutch problem.. Master or slave or Air. Cj
